colton19 Posted August 25, 2011 Author Report Posted August 25, 2011 on t3 for the sub they say the displacement is 0.46ft3 Quote 98 Jeep Cherokee XJ 2 DOOR 1 18" T3 TSNS DC 5.0K Mechman 270 Unit XS Power Flex 0 gauge XS power D1400 under hood 3 Yellow tops in rear 1990 BMW e30 325i (drift car) system to come
teardrop Posted August 25, 2011 Report Posted August 25, 2011 also what is the recommended cubes Quote
colton19 Posted August 25, 2011 Author Report Posted August 25, 2011 tbh man im sorta new with car audio http://www.t3audio.com/core.mdv/TSNS.html it has all the specs for it probably be easier for you too check xD Quote 98 Jeep Cherokee XJ 2 DOOR 1 18" T3 TSNS DC 5.0K Mechman 270 Unit XS Power Flex 0 gauge XS power D1400 under hood 3 Yellow tops in rear 1990 BMW e30 325i (drift car) system to come
tonedeaf Posted August 25, 2011 Report Posted August 25, 2011 (edited) IIRC these things like alot of port, so this is what ive got for you. 20Hx36Wx32D with a port (3 common port walls) 18.5Hx7.5Wx28L. Gives you almost 140 inches of port. 17.9 per cube. 7.76 after displacement with 34 hz tuning. Any bracing you do will slightly jump up your port and rise your tuning, but you should still be able to play low just fine. My cut sheet: Top/bottom: 36"x32" Sides: 18.5"x30.5" Front/Back: 36"x18.5" Port 1: 18.5"x23" Port 2: 18.5"4.25" Edited August 25, 2011 by tonedeaf Quote
teardrop Posted August 25, 2011 Report Posted August 25, 2011 (edited) cut list top/bottom 36x30 sides 12.5x28.5 front/back 36x12.5 port cut list top 15.5x22.5 sides 5x22.5 that is tuned to 33.16 hz port area of 70.00in port area per foot 13.64in net volume 5.13 cubes 1 extra baffle 1 comman port wall anybody corecct me if im wrong Edited August 25, 2011 by teardrop Quote
colton19 Posted August 25, 2011 Author Report Posted August 25, 2011 (edited) cool guys thanks a bunch, very much appreciated it !!! Edited August 25, 2011 by colton19 Quote 98 Jeep Cherokee XJ 2 DOOR 1 18" T3 TSNS DC 5.0K Mechman 270 Unit XS Power Flex 0 gauge XS power D1400 under hood 3 Yellow tops in rear 1990 BMW e30 325i (drift car) system to come
colton19 Posted August 25, 2011 Author Report Posted August 25, 2011 and what size MDF would you guys recommend i use? Quote 98 Jeep Cherokee XJ 2 DOOR 1 18" T3 TSNS DC 5.0K Mechman 270 Unit XS Power Flex 0 gauge XS power D1400 under hood 3 Yellow tops in rear 1990 BMW e30 325i (drift car) system to come
teardrop Posted August 25, 2011 Report Posted August 25, 2011 (edited) 3/4 in thick and use fiberglass resin inside box and port to mak stonger and seal it up Edited August 25, 2011 by teardrop Quote
tonedeaf Posted August 25, 2011 Report Posted August 25, 2011 Use enough glue and fiberglass isnt necessary. Ude either 3/8" all thread or 1/2" dowel rods for bracing for strength. 3/4" MDF is fine, id do a second baffle though. Quote
tonedeaf Posted August 25, 2011 Report Posted August 25, 2011 cut list top/bottom 36x30 sides 12.5x28.5 front/back 36x12.5 port cut list top 15.5x22.5 sides 5x22.5 that is tuned to 33.16 hz port area of 70.00in port area per foot 13.64in net volume 5.13 cubes 1 extra baffle 1 comman port wall anybody corecct me if im wrong Seems small to me and skimping on the port area for sure. Last I heard these things like around 17-19 per. Quote
