on t3 for the sub they say the displacement is 0.46ft3
98 Jeep Cherokee XJ 2 DOOR
1 18" T3 TSNS
DC 5.0K
Mechman 270 Unit
XS Power Flex 0 gauge
XS power D1400 under hood
3 Yellow tops in rear
1990 BMW e30 325i (drift car)
system to come
tbh man im sorta new with car audio :P
http://www.t3audio.com/core.mdv/TSNS.html it has all the specs for it probably be easier for you too check xD
1 18" T3 TSNS
DC 5.0K
Mechman 270 Unit
system to come
IIRC these things like alot of port, so this is what ive got for you.
20Hx36Wx32D with a port (3 common port walls) 18.5Hx7.5Wx28L.
Gives you almost 140 inches of port. 17.9 per cube. 7.76 after displacement with 34 hz tuning. Any bracing you do will slightly jump up your
port and rise your tuning, but you should still be able to play low just fine. :drink40:
My cut sheet:
Top/bottom: 36"x32"
Sides: 18.5"x30.5"
Front/Back: 36"x18.5"
Port 1: 18.5"x23"
Port 2: 18.5"4.25"
Edited by tonedeaf
cut list
top/bottom 36x30
sides 12.5x28.5
front/back 36x12.5
port cut list
top 15.5x22.5
sides 5x22.5
that is tuned to 33.16 hz
port area of 70.00in
port area per foot 13.64in
net volume 5.13 cubes
1 extra baffle
1 comman port wall
anybody corecct me if im wrong
Edited by teardrop
cool guys thanks a bunch, very much appreciated it !!! :drinks:
Edited by colton19
1 18" T3 TSNS
DC 5.0K
Mechman 270 Unit
system to come
and what size MDF would you guys recommend i use?
1 18" T3 TSNS
DC 5.0K
Mechman 270 Unit
system to come
Use enough glue and fiberglass isnt necessary. Ude either 3/8" all thread or 1/2" dowel rods for bracing for strength. 3/4" MDF is fine, id do a second baffle though.
cut list
top/bottom 36x30
sides 12.5x28.5
front/back 36x12.5
port cut list
top 15.5x22.5
sides 5x22.5
1 extra baffle
1 comman port wall
Seems small to me and skimping on the port area for sure. Last I heard these things like around 17-19 per.
