I recently installed a phoenix gold sd component set in my honda civic. I have the bass boost on both turned all the way down and the gain at only 7. I know the speakers can get much louder than they do right now but when the midbass kicks in they start distorting. I was wondering if there was any way to make the MIDBASS LOWER?
Does the amp have a low pass crossover on it. Sounds like the low pass crossover is set to low
you need your xover switch to be on hi
1. CrossoverSwitch The crossover switches on the end-panel are for setting the internal crossovers.
In the OFF position the amplifier
passes a full-range signal to the
speakers. Use the LO position when
connected to a subwoofer. The HI
position should be selected when
connected to speakers, which you
do not want to receive any sub-bass
information. Never change the
crossover "OFF/HI/LO" switch
setting with the audio system on!
2. InputGainControl The input gain control is not a volume control. It matches the output of the
source unit to the input level of the amplifier. Turn the source unit up to about 3/4 volume (if the source
unit goes to 30, turn it to 25). Next, slowly turn (clockwise) the gain on the amplifier up until you can
hear audible distortion, then turn it down a little. Adjust AMP 1, then proceed to AMP 2.
3. BassBoostControl The bass boost control is designed to give you increased output 0 - 12dB
at 40 Hz. The setting for this control is subjective. If you turn it up, you must go back and adjust the
input gain control to avoid clipping the amplifier.
Ok thanks. I Originally had them on low because i do have a sub hooked up to my other amp but when i turn it up the tweeters pop. This isnt due to to them being too high because when i set the xovers to off the popping stops. Which is my dilemma right now. xovers on high or low= tweeters popping. Xovers off= midbass causing my speakers to bottom out. I really appreciate the help youve given me so far and hopefully you can help me solve my problem.
do your tweeters have a passive crossover for them. Could be there poping because your playing mid-bass frequencies through the tweeters.
you sure the passive crossovers are hooked up correctly?
the gain is at 7 out of 10? what head unit do you have?
my guess is you just have the gain up too damn high. the reason they are not as loud as you believe they could be is because your amp only puts out 35w at 4ohm, not much.
  • Who's Online   1 Member, 0 Anonymous, 2565 Guests (See full list)
