Hey guys just got two Obsidian 12's and looking to build a box for them. I have a 2008 Jeep Liberty that they are going in and would really like to tune it low. Any help would be great. Right now I have them in a 1.5 cube slot port box.
Obsidian 12" D2:
Re: 4.0 Ohm
Fs: 33 Hz
Qms: 5.21
Qes: 0.56
Qts: 0.51
Vas: 34.4
Le: 2.21 mH
BL: 19.1
SPL: 85.4 dB
Sd: 490 cm^2
Mms: 243.1 g
Xmax: 18mm
Xmech: 36mm
Power Handling: 600 watts RMS
Recommended enclosure info:
Sealed ~ 1.0 to 1.5 ft^3
Ported ~ 1.75 to 2 ft^3 @ 30 to 35 Hz
Cutout: 11.10"
OD: 12.5"
Mounting depth: 6.75"
Mounting flange to top of surround: 1.25"
Displacement: 0.16 ft^3
The ideal alignment per 12" woofer is 1.75 ft^3 tuned to 32 Hz.
I've got my three 12's in 2 ft^3 each tuned to 30 Hz and the low end is a bit on the retardedly loud side. They are literally tearing my CRX apart bit by bit. I'm having to rip everything out and bolt down the enclosure because it jumps too much if I play screwed music. I enjoy how they sound but the extra 0.25 ft^3 per driver is not necessary in order to get them to play loud or low.
Electrodynamic
Power handling is not a power requirement! Don't install suckage!
Simon Eichenberger is the man.
My PM's are disabled.
Ok guys would love to know how to figure out the dimensions for this box, I am running a Sundown 1500d v2 on them and never really go into port tuning and all that so all the help would be great.
download the torres box calculator
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Or you could pay ray or ram to design it.
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
