Need help with a box for jeep liberty
Hey guys just got two Obsidian 12's and looking to build a box for them. I have a 2008 Jeep Liberty that they are going in and would really like to tune it low. Any help would be great. Right now I have them in a 1.5 cube slot port box.
Obsidian 12" D2:
Re: 4.0 Ohm
Fs: 33 Hz
Qms: 5.21
Qes: 0.56
Qts: 0.51
Vas: 34.4
Le: 2.21 mH
BL: 19.1
SPL: 85.4 dB
Sd: 490 cm^2
Mms: 243.1 g
Xmax: 18mm
Xmech: 36mm
Power Handling: 600 watts RMS
Recommended enclosure info:
Sealed ~ 1.0 to 1.5 ft^3
Ported ~ 1.75 to 2 ft^3 @ 30 to 35 Hz
Cutout: 11.10"
OD: 12.5"
Mounting depth: 6.75"
Mounting flange to top of surround: 1.25"
Displacement: 0.16 ft^3
The ideal alignment per 12" woofer is 1.75 ft^3 tuned to 32 Hz.
I've got my three 12's in 2 ft^3 each tuned to 30 Hz and the low end is a bit on the retardedly loud side. They are literally tearing my CRX apart bit by bit. I'm having to rip everything out and bolt down the enclosure because it jumps too much if I play screwed music. I enjoy how they sound but the extra 0.25 ft^3 per driver is not necessary in order to get them to play loud or low.
Electrodynamic
Power handling is not a power requirement! Don't install suckage!
Simon Eichenberger is the man.
My PM's are disabled.
3.5-4ft^3 with a low 30's tuning will work well. Unless you're running under 1kw to the pair, there's really no need to go larger. Or you can try a bandpass.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
download the torres box calculator
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
  • Who's Online   1 Member, 0 Anonymous, 1535 Guests (See full list)
