also when was the last time you ran fuel system cleaner in your truck? the mesh on the fuel pump might be clogged too. do this before you spend a whole bunch of time dropping the tank and doing all that. go fill up your tank, buy a can of seafoam, dump it in. and let it sit overnight. then in the morning drive it for a lil while 5-10 miles and see if that makes a difference.
alright guys well thanks alot for all of your help
if you had a leaking gasket you need to make sure your head gasket isnt bad as well it will cause alot of those same problems. also find an obd2 scan tool that does live data and watch what happens when your truck has those issues it will tell you the problem pretty quickly
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
yeah i been looking at those
You can check for a leaky vac line with starting fluid just spray the lines when the motor revs up/down you have found the leak test by spraying some into the intake first so you know what your listening for, and if your head gaskets are bad you would have oil in the water or water in the oil, lots of smoke from the tail pipe or excessive oil leaking down the block. either way it would probably overheat, do you hear a creaking noise coming from the pass side of the dash?
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
a creaking noise? i dont think so? and how do you check for vacuum leaks under the dash?
If I were you I would just take it to a shop most give free estimates if its under the dash the you've got your work cut out for ya bud, hope ya figure it out.
Kenwood KIV-BT900
Front Stage
RE 6.5 125.5.
Lanzar Max Pro 6.5
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
  • Who's Online   1 Member, 0 Anonymous, 1370 Guests (See full list)
