ThatGuyWithAJetta Posted August 28, 2011 Report Posted August 28, 2011 So i have two rockford fosgate 10 inch punch z subs and a pioneer 4 channel amp. So my problems is in order to be able to get down to four ohms i need to wire my subs in parallel so i was wondering if i had it switched to the two channel setting if i could run a wire from each channel to one terminal. Thannks in advance, KCowboy620 !999.5 Volkswagen Jetta 1 Planet Audio BIg Bang 15 Powerbass 1500,1
tonedeaf Posted August 28, 2011 Report Posted August 28, 2011 Is the 4 channel even bridgeable? Or you plan on running on 1 channel per sub? Is it a full range amp with subsonic and LPF? Not sure if the pioneer amp will work...
ThatGuyWithAJetta Posted August 28, 2011 Author Report Posted August 28, 2011 Yes it is bridgeable, i was planning to run one channel per sub but now i have to run the subs in parallel which is why i was asking if i could run two channels to one terminal, and it has a lpf but no subsonic from what i can tell. !999.5 Volkswagen Jetta 1 Planet Audio BIg Bang 15 Powerbass 1500,1
