From what ive read this should work if im adding a second battery to my trunk.
looks good. what size wire you runing between the batts??? and are you thinking of big 3 upgrade?
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
Big 3 upgrade is done and all the wire is knu konceptz 0 gauge, i know im missing a fuse between the alt and the front bat but ill add that in later. Ive never added a second battery i just wanted to be sure i had the right idea. Thanks man
Walled Police Interceptor
Four 15s
160s
If your power wire from alt to batt is not fused take it off until you fuse it. No need for a fire.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
yea thats a huge deal hehe in my opinion i have it set up the same way besides having 2 grounds per batt it helps alot! check out my build. you can see how i did mine ill update more pics tomarrow as well for my rear batt. have any questions just pm me
http://www.stevemeadedesigns.com/board/topic/117429-2001-volkswagen-gti-rf-system-build/
BIG 3
RF T400.4
all stinger wires
Sweet lookin build everything looks clean, ill check back on it
Four 15s
160s
Ive got another question for anyone, when im grounding my battery in the trunk could i ground it to the same location where the amp is grounded or should i find a new separate spot on the frame.
Thanks!
Four 15s
160s
