Box Design For 4 L7 15's
if ur doing a wall right behind the front seats then i really dont see it being a problem...
i likes me some audio stuff...
No...My bad. The wall is behind the rear seats. My fault, I cant believe I didnt say that erlier,im sooo f'n retarded.
all those dimensions or behind the rear seat.Thats why I asked about the port at the top
how about a port from the top of the box to the top of the back seat...so 23.5"tall (25-1.5 for the double thick wall at the top) then it could be 13"wide and 16"deep, giving you 305.5sq" of area (12.8/cube), 23.9cube enclosure (5.97/sub) tuned at 33.66hz?
Fuckin PERFECT!!!!!Thanx for your help!!!!!This is gonna be sic! I wish I had TL to meter it when its finished!!!!!!!!Much alohas!
here ya go! did this last night...the only thing i messed up on is that the top of the port is suppose to butt up against the top of the box...and for some reason i made the hole cut out really small...although the outer diameter is correct....and you might wanna double check, because if those 15s are any bigger than 15.25" or 15.5" then some things may need to change b/c shit is a pretty tight fit...
Posted Image
Posted Image
You are truely a fuckin IDOL!!!!!!!!!! You've helped out so much! I cant wait till the box is finished...I'll definately make sure design credit goes towards you.....Thank you soooo much!
ALOHAS and MAHLOS!
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
