teardrop Posted September 3, 2011 Report Posted September 3, 2011 ok i got a 98 blazer and my sun roof is broke and i want to replace it with a pieces of sheet metal welded in and ill need do use body filler after i grind down the welds how well will the body filler hold up on the roof probably use fiberglass strand filler
dereileak Posted September 3, 2011 Report Posted September 3, 2011 not to bad, but needs to have some kind of coating over it, I would do a rough surface below the body filler so it can grip good, otherwise it wont grip as well, the more surface area the better 2006 Mazda3 Hatchback Black 5 Spd ManualPioneer 4300DVD2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)Kicker 10ZX2500.1 (2845 RMS) Sub AmpKicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)Kicker KQ3 Active CrossoverKicker KQ30 EqualizerKicker 09QS60.2 Components (Woven Carbon Cones)Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -) 1/0 Gauge KNU Kollasal Flex (1 Run for -) 300 Ft Kicker X-Series 16 Gauge Speaker WireXS Power D3400 (Rear)XS Power D3100 (Front)Singer Externally Regulated Alternator (Being Built)+ The Love for Car Audio and BASS <3UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
teardrop Posted September 3, 2011 Author Report Posted September 3, 2011 ok plus doing some metel strips under for support and sound deadner try to keep it from flexing as bad you think it will hold good
Leboy23 Posted September 3, 2011 Report Posted September 3, 2011 Shouldn't have a problem if you brace under it, and if it's done right. 2012 Nissan Altima SL DC M2 Lvl 3 12" with AR cone DC 1.2K Amp Kicker Sum8 Kicker 4 Gauge amp kit XS Power D2700 1.5 Cubic ft net tuned to 38Hz
teardrop Posted September 3, 2011 Author Report Posted September 3, 2011 cool thanks guys i ant to bad with a mig took a few classes for it and some body repair classes so should be ok
