im wiring up my DC 12" lvl 3 D2 up to my Hifonics HFI1000.d. And the amp has 2 positive and 2 negative speaker inputs. Im wiring it up to 1OHM, which is 1000RMS. So i dont know what to do? please help me!
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
cheapo Legacy coaxes (just for now)
all you have to do is just wire the woofer in parallel and it will give yu 1ohm
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
yeah i got that. but i have 1 positive and 1 negative going out of the box. so do i split it into both positives and negatives on the amp to get max RMS at 1 OHM???
2 DC 12" lvl 4s
1 DC 1.2k
XS Power S3400
big 3
Alll KNU wire
Pioneer HU
If it's a single channel amp, the inputs are internally connected. Just use one positive, and one negative
2001 chevy cavalier
Rebuild in progress
what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2.
well...as i see the level 6 is compared to a lamborghini.....but a corvette?
i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
If they are Dual 2 Ohm you cant get a 1 ohm load. You can only get a .5 Ohm load and a 2 Ohm load ( And 8 But thats a little high. ) . And i dont suggest a .5 Ohm load assuming you dont have proper electrical. Here is how you wire 2 ohm.
And i highly doubt you would want to run that hifonics at .5 ohm anyway.
And if its a Single Channel / Monoblock, You can use either Positive and Negative output blocks, They are internally connected, so it wont matter. And it has two positive and negatives so your not cramming tons of wire into one positive and negative terminal block.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
  • Who's Online   0 Members, 0 Anonymous, 2007 Guests (See full list)
