Sub turn on malfunction
When I can get ahold of a screw gun I'm gunna take the sub out and check connections. I really hope that it is a lose connection somewhere inside the enclosure. I really don't think that the woofer is blown because i smelled the port to the enclosure and I didn't smell anything abnormal and there is no audio distortion at all when the woofer is bumpin'.
1996 Jeep Cherokee Country
Sony CDX-GT240 Head Unit
Sony XM-ZZR3301 1100W Max ZR Series Class D Monoblock Amplifier
Alpine SWR-1243D 12'' Dual 4 ohm Type-R Series Car Subwoofer
2x Alpine SPS-510 5-1/4'' Coaxial 2-Way Speaker Set
2x Pioneer TS-G1344R 5-1/4'' Coaxial 2-Way Speaker Set
Fully Insulated with Peel-N-Seal
It stopped working today all together, checked it with a 9v battery.. it's definitely blown.
I'm a dumbass for wiring it up incorrectly
Ok guys lemme know if I infact did wire it up incorrectly.. I tried my best with this:
I talked to a speaker expert and he said that I should have ran 4 wires from my amp to my sub 2 for each pos and neg because I was infact only running half of my amp on the sub. Can someone explain?
Amp : 330 watts RMS x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
Sub: 12" Dual 4 ohm Type R Subwoofer
Power Handling:
Peak: 1800 watts
RMS: 300-600 watts
Power Handling:
Peak: 1800 watts
RMS: 300-600 watts
The way you have it wired was wrong. Whoever it was that explained it how to wire that sub was right.
Speaker Outputs: Although this is a mono amplifier, there are screw terminals for two speakers (each terminal is 0.35" wide). They are not stereo outputs, but summed (L+R) mono, and internally wired in parallel. If you connect two 4-ohm speakers to the amp, the amplifier will see a 2-ohm load.
came straight from crutch field... http://www.crutchfield.com/p_158ZZR3301/Sony-Xpl-d-trade-XM-ZZR3301.html?search=xplod+amplifiers&tp=115&tab=detailed_info
read the input and output notes.
Well it was a 160$ lesson.. Thanks man
/close thread
  • Who's Online   0 Members, 0 Anonymous, 1767 Guests (See full list)
