If you are willing to spend the money on 1 inch MDF, then get 3/4 or 1 inch birch plywood (11-13 ply) instead. Stronger and much lighter, way easier to work with too.
With what you plan on running, 3/4" MDF with a double baffle and a little bracing in the right spots will be fine.
My Saab 9000 build
1993 Saab 9000 Aero 5spd
Just Say No To Rear Speakers
Just Say No To CCA Wire
Real Men Drive Stick
I would use 3 layers of 1" birch, steel bracing and 3" steel rods every 8" inside cabinet along with a layer of concrete in between each layer and 1" thick of fiberglass inside and use case hardened steel aero port, plastic flexes..
If you can afford it, buy a couple concrete light poles and cut them down as bracing inside the box instead of the steel rods. Also, use titanium 3/4" bolts to mount the subs that way they don't break. Also... what about deadener?? I would use 16-20 layers of Alpha Damp on EVERYTHING in the vehicle and I would look into installing a stripper pole every 2 square feet to minimize flexing...
That would be my ideal setup for what your doing... <_<:santa:
No way I was thinking of a build similar to this. Was gonna start it in my 82 Ford fiesta twin Turbo type chex
wide body kit right?
