08 Chevy diesel remote start problem
Put In a viper remot start 2 way a few weeks ago it takes a resistor for the starter and pulled tach off the cam sensor. I have tried to use all the options for tach sens and voltage. But when it's first started in the morning it Trys starting by bumping the starter instead just running the starter till it starts also it has stuck the starter on till I went in and shut it down the remot start by pressing the brake. Anyone seen this and know what it takes to fix?
How are you bypassing the transponder portion of the key? You will know it has a transponder in the key if the key shaft has a circle with a plus sign stamped in it. For a tach signal, try looking for a light blue/black wire located in a large harness on top of the motor on the drivers side of the engine, or you can try at a fuel injector. Good luck!
So, I don't have anything cool here yet. It's no big deal
does it need wait to start? not sure if hte newer diesels do or not.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
adjust the crank time?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
if it stays cranking after a start do you have the tach right? Id verify that.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 1517 Guests (See full list)
