Ok as most of you guys can see i just acquired a new T4k. LATER I will be adding a T8004. For now what size fuse should i run for JUST the T4k from the bat to my second and 3rd bat? I know that amp draws a TON of current so i will be selling more stuff later on to get a bigger alt. but for now what size fuse should i run inline for the amp?
NoFearX18 said:
trainman0978 said:
i cant remember whats in there i could look but i havent unwrapped it yet. i was thinkin 300A-350A for it
NoFearX18 said:
trainman0978 said:
aight now i need to find a place to order a few
http://sonicelectronix.com/item_3894_Kicker+ANL300.html i found this but i KNOW i can get them cheaper
NoFearX18 said:
trainman0978 said:
x2 im pretty sure its 500A the sonicelectronix specs say 300 but i believe that is from the T3K. but DONT run a 500A fuse on your wire, i wouldnt do anything more than 300 assuming its 1/0.
play Moola.com its actually fun and free...
click here to join Money games!
its just games with free money!
X2 Id run atleast 2 runs of 1/0
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
B)-->
QUOTE(Eric B @ Nov 1 2007, 03:21 PM) 186675[/snapback]
that's what i'd do bro, run two runs and when you throw in that T8004 you'll be set. put a 300amp fuse on each run of 1/0, after battery and before next battery.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
