what wiring configuration is this?? please help fast
Well we can't really say that were your gains are set isn't clipping, and you could have been clipping on your head unit as well. How dis you set your gains? Just by ear?
yah by ear, i told the stereo place i had it set just under half and they said it would be fine as long as i didnt crank it up or turn the bass boost up. and i dont know any other way to set them. how could i tell if i was clipping?
Current system:Front stage: Alpine type s 6.5No rear:Alpine type s 6.5headunit: alpineAmp: Jbl bp600.1
Sub: Alpine type x 12
dont know much about them. Found a "FLUX" Capacitor on ebay. If I add this to my system, can I really travel into the future? And how far into the future? That probably all depends on how I ground it though, right?
Dude dont even waste your money on capacitors get a second car battery preferably a kinetik or stinger or any other car audio battery use the battery that is correct for your systems true rms wattage do some research on the net for this. Go to kinetiks website they explain how to pick a battery from thier site that fits your system. :shrug:
subwire.jpg this is what it looks like but my sub is more circle and my amp more rectangle and theres a box.
Well if your OA smoked on 600watts it's almost a sure thing you were clipping some way. Unless you got a faulty sub im sure you would have known that a long time ago since you've already had it for a month
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Pics of wiring would help also. Positive to Positive to Positive on amp, and Negative, To Negative, To Negative on amp should be 2 ohms final load. Sounds wired correctly, but then again. Are you sure you were not clipping it to hell? And when you said "They" Built your box.. Who is they? And did they do anything else?
sorry i didnt see this post and the place is called inovative sound solutions (ISS) and all they did was build my box
how can i tell if im clipping and i just looked at the voice coil and it doesnt look burnt and it moves in and out and theres no rubbing that i can feel/hear
So turn your gain down just a tiny bit and see if it still works. Just cause it smoked doesn't always mean it's blown, but it's never good
so far...
should i see if it works and then sell it or keep it. i mean does that mean its closer to blowing or what
the reason your sub went out that fast is you did not allow the woofer to be broke in, from the factory the suspension is verry stiff, they need to be played gently till the suspension is loosened up. this will normally take a week or two depending on the hours of use, 20-25 hours is usualy good @ arround half power. then let it rip
Edited by matty matt
the reason your sub went out that fast is you did not allow the woofer to be broke in, from the factory the suspension is verry stiff, they need to be played gently till the suspension is loosened up. then let it rip
i had the gain turned almost all the way down for about 2 1/2 weeks
That is not true, it's a common rumor, but even nick and Jacob themselves said you don't have to have a break in period, they will just start to sound better as they get broken in. That is NOT why your sub smoked! Disregard that comment lol
so far...
  • Who's Online   1 Member, 0 Anonymous, 1556 Guests (See full list)
