Hey guys im working on my first bix box project. I got 4 13.5 w7's that i would like two put in the back of my hummer.
The measurements for the space i could put it in is around
46.5" wide
31" deep
18" tall
The specifications of the speakers are
Free Air Resonance (Fs): 23.5 Hz
Electrical “Q” (Qes): 0.476
Mechanical “Q” (Qms): 7.517
Total Speaker “Q” (Qts): 0.448
Equivalent Compliance (Vas): 3.68 cu. ft. / 104.3 liters
One-Way, Linear Excursion (Xmax)*: 1.25 in. / 32 mm
Reference Efficiency (no): 0.269%
Efficiency (1W/1m)**: 86.3 dB SPL
Effective Piston Area (Sd): 107.35 sq. in. / 0.0693 sq. m
DC Resistance (Re): 2.41 ohm***
Nominal Impedance (Znom): Dual 1.5 ohm
Thermal Power Handling (Pt): 1500W
Driver Displacement: 0.21 cu. ft. / 5.9 liters
Net Weight: 52 lbs. / 23.6 kg
If anyone could help me on this it would be very appreciated
Because im clueless on a start :help:
You already have the subs? I'm thinking you are going to want more airspace for 4 of them!
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
Well I'm thinking you don't have enough room with the stated dimensions for 4, is there no way to get more room out of your hummer??
so far...
with those dimensions, you have 12.68 cubes, gross
after sub displacement, it knocks it down to 11.84
not to mention port, and bracing disp.
dont think you have enough for all 4 :shrug:
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
