i have a memphis mojo 15-cm15d4 and i am powering it with a rockford fosgate t1500-1bdCP. i am overpowering the amp and the sub by about 250 watts. this makes the sub and amp a little warm but not anything terrible. now how much would i be able to throw at it if say, i got another t1500-1bdCP? im thinking the only reason the sub is getting hot now is because the amp is getting hot. think i'd be able to throw 2.5k at it?
how do you over power your amp with your sub ? and if your worried about over powering your sub with the amp you have now why would you add a second 1500, which would equal 3k not 2.5k yes maybe after box raise and depending on voice coil impedance i may be wrong but without full information isnt much i can help with
im overpowering my amp now to 2k watts. and i figure if i get another t1500-1bdCP i can run them both at 1250 rms and put out a 100% clean signal, making everything run cooler and having more power, then i would do that. just asking for a secon opinion
Dont be an asshole orion i havnt been one yet, but You arnt over powering your amp your clipping it which is one bad for your sub and amp, Now let me ask how did you set your gains on the amp?
dmm. and the amp doesnt even get hot so im not clipping lol. maybe a tiny tiny bit but nothing to wear it can fry. ive had this set up for about 7 months now and havent had a problem. ive listened to it for 2 and a half hours straight at one point and it doesnt get anything other than warm.
Your first post you say it gets warm,, and if your having no problem then what are you asking? your contradicting yourself now
I was thinking the exact same thing.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
im asking will i be able to run 2.5k to my sub instead of just 2k if i get another amp, and run them at a lower rms. this would make the signal clean with no clipping, keeping everything cool. basically do you think my sub can handle 2.5k
I dont know anything about the sub but why not get another sub and amp to have double the cone area to be louder and not worry about blowing the sub from over powering ? seems more ideal
  • Who's Online   0 Members, 0 Anonymous, 917 Guests (See full list)
