Tek Posted September 10, 2011 Report Posted September 10, 2011 so I have a DMM that I plan on setting my gains with on my Audiopipe 1500.1D. I have an RCA bass knob and I have the bass knob that came with the Audiopipe amplifier. I want to set the system up so the bass is controlled entirely by the bass knob and not at by the radio. 1.) can that be done? 2.) which bass knob do I use? 3.) how do I do it?
MACnonsence6 Posted September 10, 2011 Report Posted September 10, 2011 run the inline rca bass knob and that will controll the signal sent to the amp but the basknob that comes with the amp kinda does the same thing so eather way ur set I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Tek Posted September 10, 2011 Author Report Posted September 10, 2011 run the inline rca bass knob and that will controll the signal sent to the amp but the basknob that comes with the amp kinda does the same thing so eather way ur set and do I set the gains with the RCA knob turned up or turned down?
bassrace Posted September 10, 2011 Report Posted September 10, 2011 You'll set it where ever you want to set it or what ever sounds the best. Prob with the knob around halfway but its up to you 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry
billy101 Posted September 10, 2011 Report Posted September 10, 2011 run the inline rca bass knob and that will controll the signal sent to the amp but the basknob that comes with the amp kinda does the same thing so eather way ur set and do I set the gains with the RCA knob turned up or turned down? I know some people will set the gain with the bass knob not turned up all the way up so that some songs that are "quieter" than other songs, you can turn the knob up some more to fill in the bass that's "missing". Basically to make the quiet bass a little bit louder. I don't have a bass knob on mine so I cannot really comment from experience. First System 2002 Impala LS 3.8L V6, 128,365k miles. Alternator: DC Power 190Amp H/O Alternator Headunit: Kenwood KDC-BT945U. Speakers: MBQuart 6.5" Comps, 6x9 3-way. Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm. Box: 3.1cuft box tuned to 33hz. sealed off to cabin Big 3- done with all Knukonceptz KCA 0 gauge. Don't drop below 14.1v at full tilt.
kl0wn Posted September 10, 2011 Report Posted September 10, 2011 and do I set the gains with the RCA knob turned up or turned down? If you are going to be using the external knob that sits up near the driver seat with you. Plug it up, and turn it all the way up. Best way to do this is set the gains on the H/U as you would have them daily just beating, and then tune the amp to those settings. If you're going to normally have the external bass knob hooked up and using it, keep it plugged in & turned up, then get to tuning. 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
Tek Posted September 10, 2011 Author Report Posted September 10, 2011 alright, thank you for the help everyone. SMD has the right fuckin' idea.
