may03LT Posted November 1, 2007 Report Posted November 1, 2007 Ok I have the specs for my enclosure but I need to include bracing and the corners in the design. So, how do I take the dimensions of the braces and convert them to ft3? And what about the 45s? If more info is needed just ask. Thanks!
andym85 Posted November 1, 2007 Report Posted November 1, 2007 same way you find box volume...say if you are using a 2 x 4 that is 10" long (granted they arent exactly 2 x 4..but...) then you just do 2*4*10=80cubic"...80/1728=.0463cubes....unless you are using a bunch of bracing you can see that it almost isnt worth figuring up since it doesnt take up that much.... as far as the 45's go....just measure how far you go in both directions from the corner. like say from the corner of the box you measure down 5" and then measure across 5" and then you put your 45 in there...all you do is take 5" x 5" x whatever height your box is. then take half of that answer since its a triangle and divide it by 1728...so say your box is 10" tall...you would do 5*5*10=500...500/2=250...250/1728=.14468cubes i likes me some audio stuff...
may03LT Posted November 1, 2007 Author Report Posted November 1, 2007 same way you find box volume...say if you are using a 2 x 4 that is 10" long (granted they arent exactly 2 x 4..but...) then you just do 2*4*10=80cubic"...80/1728=.0463cubes....unless you are using a bunch of bracing you can see that it almost isnt worth figuring up since it doesnt take up that much....as far as the 45's go....just measure how far you go in both directions from the corner. like say from the corner of the box you measure down 5" and then measure across 5" and then you put your 45 in there...all you do is take 5" x 5" x whatever height your box is. then take half of that answer since its a triangle and divide it by 1728...so say your box is 10" tall...you would do 5*5*10=500...500/2=250...250/1728=.14468cubes Right on bro thx for the help
andym85 Posted November 1, 2007 Report Posted November 1, 2007 no prob i likes me some audio stuff...
