Ok so I have a 18" solo x dual 2ohm I have it wired to 1ohm but the amp I bought is 2600 watts at .5ohm is it a bad Idea to hook it up to the .5ohm would it hurt the amp or sub thanks in advance
the amp is a TX1.2600d from soundstream
Hi SMD Members If anybody has computer problems and is an SMD member with at least 150 posts I will fix your problems for free by phone support or I can also fix your computer over the internet.... I have references such as All State insurance, Nationwide Insurance and much more... just p.m me for help.. I am not the greatest with when it comes to audio systems so I figured I could contribute to the forum this way.... Thanks David
ive edited my post three times, can you clean up what your trying to say, i cant understand if you mean wiring the sub to .5 or the amp being .5ohm rated and running a dual 2 sub to it.
Edited by ChevyBoy95
sorry Im new to car audio... the amp is 2600 watts at .5ohm and it has on the amps speaker terminals ]----.5----[ i would like to get the most power so is it safe to hook up my 1ohm sub to a .5ohm amp I think its called bridge
Edited by DK99
Dual 2 ohm can only be wired to 1 ohm and 4 ohms
2001 chevy cavalier
Rebuild in progress
what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2.
well...as i see the level 6 is compared to a lamborghini.....but a corvette?
i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
I understand that what I was wondering is it safe to hook it up to the .5ohm bridge connections would it blow the amp or sub
besides the fact that its impossible for you to wire to half ohm with a single dual 2 ohm woofer, if you DO wire to half ohm, your woofer and amp wont blow if you watch your voltage and clipping.
Ok thanks. I know the sub could not be wired to .5 ohm just asking what would happen if I did connect the sub to the .5 on the amps speaker terminals....... my voltage stays up at 14v all the time
yes, its fine if you wire the sub to your amp at 1 ohm, it just wont put out the power it does at .5, but you wont be jeopardizing your equipment, its fine
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
there is no special half ohm hookup on the amp. there are two pairs of speaker terminals to just make wiring multiple subwoofers easier. you can choose whichever + and whichever - you want and it will work the same.
It´s a monoblock with 2000 w at 1 0hm. It´s bridgeable if you have another TX1.2600d to bridge it with, but maybe not in 1 Ohm as it seems in the specs. You should ask Soundstream.
