i was told that the T2500BDCP gives you the 2500 rms no matter where your voltage is that i could be below 14.4 and still get the 2500 rms that is what constant power means is it true or false
Edited by KHRISS
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
lets say my subs are wired at 1 ohm and my voltage is below 14.4 can i still get the 2500 rms under 14.4 volts cause u know how some amps give you 2500 rms at 14.4 volts in 1 ohm load then when your voltage drops you lose power does that applies to the 2500bdcp
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
2500 at 14.4 volts so what happens when you go below 14.4 do you still get those 2500 rms at 1 ohm load
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
yes but dont have it drop too low or kablewie
SOLD
2006 Ford Ranger Single Cab
2 DC XL 15's
2 Crescendo BC2k's
4th Order Blowthrough
CURRENT
2012 Dodge Charger R/T
2 Tantric HD 12's
Ampere 3800
2 XS XP 3000's
if your worried about getting 2500 watts from at T2500bdcp @ 1ohm, either your voltage is dropping bad, or you have a stupid amount of rise, that amp will put out rated no problem. some of the birthsheets are as high as 3600 watts @ 1 ohm
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
are you serious 3600 rms damn thats exactly what i want more bang for my buck NICE JOB FOSGATE
Edited by KHRISS
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
all amps work the same way ... they are like a car ... it will only go as fast as the air and fuel you give it. same with an amp it will only give out as much power as you give it voltage and all rockford amps are tested at 14.4 volts but they put out way more than rated ... i have a t1500-1dbcp and its birth sheet said 1909 at 1ohm so at a lower voltage i know it will put out ~1500 but you want to ideally keep your voltage a good high number for best performance
so thats what constant power means right ill get the same power at a stable loud at any voltage right YES O NO
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
so to keep my voltage stable or high what do i need besides 2 good batteries and the big 3 ?
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
