NO. Sell the boss, build a new box for the subs you have. Don't get a third sub, unlike in people, audio "oreos" don't work.
you are scared that getting rid of that third sub will make you quieter. drop that.
go to the subwoofers/enclosures section down below
up at the top is a sticky called Torres box calculator (or something to that effect)
download it
find the recommended box specs for those woofers
begin designing the box remembering that 12-16 sq inches of port per cube is a good starting point
once you get the box correct and at the desired tuning freq then you build
there is a cut sheet at the top right of the program
good luck. it is not difficult and i bet itll be a fair bit louder
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
What about buying a third Orion 12"
Do it.... Give us your max dimensions for a box so one of us can make you a design.
I'd work on a new amp for now though.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Be really careful on the gain, meaning DO NOT turn it up all the way its impossible for me to tell you exactly where to set it without being there. But low pass at 80hz should be fine, for the highpass/subsonic its hard to say..... Its a sealed enclosure right? If so you Might not need the subsonic on.......
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Is the enclosure sealed? Is it the same box, with the boss sub removed?
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
  • Who's Online   0 Members, 0 Anonymous, 1556 Guests (See full list)
