Well guys here is the problom, everytime i turn off my headunit to turn my amp off there is a bass output for about 1 second. What could be causing this noise? Could it be doing harm to my sytem?
-Alpine CDA-102
-Rockford Fosgate T1652
-Rockford Fosgate P1652
-Audioque 2200
-Fi Btl N2 12
-KCA Karma 0 Gauge Power
-KCA Karma 0 Gauge Ground-Sound deadened trunk and doors
You can ground your rca's that might help. Are your rca's running next to any other wires? Also are you grounds good?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
yes my rca's are next to power and ground and my ground is not very good either.Might have change a couple things up.I just installed the system yesterday so it was kind of aa rushed install.
-Alpine CDA-102
-Audioque 2200
-Fi Btl N2 12
Thats most likely whats causing it. Run the rca cables on the opposite side as the other wires. And get a good ground spot and sand it down to bare metal. That should cure your problem.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Will do thanks for the help!
-Alpine CDA-102
-Audioque 2200
-Fi Btl N2 12
how would i go about go about doing this, never heard of doing it either?
-Alpine CDA-102
-Audioque 2200
-Fi Btl N2 12
Grounding rcas?
Take a peice of speaker wire, take off the plastic housing/jacket wrap it around the headunits rca jacks. Then take the end of the wire and use a screw in the deck wrap the wire around and screw it tight. :)
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Grounding rcas?
make sure its not touching the inner probe part!
make sure its tucked in lol
  • Who's Online   0 Members, 0 Anonymous, 582 Guests (See full list)
