They sew them on just like how you were going to glue them on but you cannot sew them unless you have the ability to get to the top and bottom of that first spider on your sub if its a multiple spider sub. Manufacturers take the tinsel leads and give them some slack and then sew them on either every other or if they are overkill every rib. They sew the part of the rib that goes down like the valleys of the spider. Again do NOT attempt to do this if your sub has more than 1 spider on its suspension because if you do you will screw up your spiders and cause the sub to have horrible suspension since it will lack the ability to move like it should.
2004 GMC Envoy1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps0 gauge power wire from front to backAlpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunitSundown Audio SAX-200.4 amp for my mids and highs8 gauge speaker wire from amp to woofer270 amp Mechman AltRockford Fosgate T1652-s component speakersRockford Fosgate 3Sixty.2 sound processorRca's from Rockford Fosgate and Monster Cable14 gauge speaker wire for the mids and highs1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcapBox: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lightsLink to my build: Buildupdates/progress
they make curved needles why couldnt i do it with the recone already in? then put a drop of ca glue that would leak under and glue the bottom as well
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
You could do it but you have to make sure you didnt grab more than just the one spider thats at the top. The glue isnt really necessary. For most of the tinsels ive seen that were stitched they are stitched 3-4 times over eachother. So id do one pass and repeat it back and forth 3-4 times and then tie it all up nice to prevent it from loosening. You want a good amount of slack on the tinsel leads themselves too.
im going to be adding another 3" so theyll have plenty of slack.i only got one spider with this recone. re se from fi.
so id stich from to the high rib
Edited by hifonics10
no, you stitch the valley/the low part of the rib. Stitching on the high part has a low success rate. Stitch it on where the rib looks like its going down to the motor of your sub or like if you were to pour a cup of water on your spider back, the water would be sitting in the lower area of the spider, not the higher part.
alright when my leads get here ima do that sick of this shit lead slap and having to worry about the leads breaking at the cone :( if i knew how to re string them from the cone id re wire them all so there was no breaks/
Yea i hear ya on that. I had a few subs with lead slap and its annoying to all hell and made me think i was bottoming out the sub at very low power and it wasnt. I saw my mids from fosgate have the leads woven into the spider of my speaker but i wouldnt try that at all with a sub since they move so much more than a midrange speaker would.
a friend gave me a pyle square 10 that the cone broke apart from the coil but there leads are flat and are just clued on the top kinda kool. couldnt do that with mine hopefully i can stich then and not fuck up sick of lead slap and worrying or worrying about them breaking off at the cone
You shouldnt be able to screw it up, just take your time and make it as tight as you can for where it forms around the tinsel itself and knot the string so it wont come apart. Also be careful to not rip the spider from going in and out a lot with the needle.
edit: if you really want to be smart grab an old woofer if you have one that also has a single spider on it and try to sew the tinsel down on that one for practice.
Edited by kickass audio
i have mad old woofers but there all being used lol im a bit of a old school colector. ima take my time and get it right. this sub needs to be reconed anyway because of that but hopefully thatll prolong it long enough for me to get the money to recone it wich brings me to another question.
i have what i beleaive to be a pair of newer stlye re se motors on standered 12 spoke baskets. one reconed with a recone from fi but im not sure if that recone will work with the newer motors on 12spoke baskets as the new ones are on 4 or 6 spoke "dont remember" it has worked for the past 6 months or so ive had it but ive been wondering if i can stuff a 05 xxx recone in that motor. if so what benafits i get.
like what would be better in the same aplication 1 stock re se d4 wired to 2ohms on an ap1800 or 1 re with maxed out options from fi running d2s wired to 1ohm?
  • Who's Online   0 Members, 0 Anonymous, 1476 Guests (See full list)
