988216855 Posted September 26, 2011 Report Posted September 26, 2011 about how many feet will i need to wire two sa 12's dual 4 ohms down to 1 ohm?
adam6604 Posted September 26, 2011 Report Posted September 26, 2011 I bought 30ft to do my 15's. 30+ would be safe considering it's not that expensive , get atleast 10awg Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi. Audio: Two 10" Alpine Type R's ( 1000rms models ) Hifonics BRZ 2400.1D @ .5 ohm Two Kinetic 1400 batteries ( soon to have XS power under hood ) Tsunami 1/0 Awg wire throughout truck. Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine. Exterior: 17"Dick cepek rims with 33" Toyo MT tires Bushwacker fender flares Magnaflow true duel exhaust LED tail lights with Projector headlights Plasti-dip fun coming soon!
CaptainzPlanetz Posted September 26, 2011 Report Posted September 26, 2011 about how many feet will i need to wire two sa 12's dual 4 ohms down to 1 ohm? Depends on where your amp is mounted, like how far away is it from your subs? And you will be gravy with 12gauge, you don't need to over do it and waste wire you have to cut away to get it to fit in the terminal ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
988216855 Posted September 26, 2011 Author Report Posted September 26, 2011 about how many feet will i need to wire two sa 12's dual 4 ohms down to 1 ohm? Depends on where your amp is mounted, like how far away is it from your subs? And you will be gravy with 12gauge, you don't need to over do it and waste wire you have to cut away to get it to fit in the terminal the amp will be in front of the box, real close to it. i was thinking 10 gauge but i'll do 12 if it don't really make a difference.oh and the speaker wire will be coming out from the port which will be close to the amp.
kam311 Posted September 26, 2011 Report Posted September 26, 2011 It depends on how far your amp is away from your subs lol. And there are a couple reasonable ways to wire it. I'd wire each sub individually to the amp. And you will need jumpers to go between the voicoisnon each sub, which is about 12" (on the safe side) per sub. But other than that just measure and see so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
CaptainzPlanetz Posted September 26, 2011 Report Posted September 26, 2011 about how many feet will i need to wire two sa 12's dual 4 ohms down to 1 ohm? Depends on where your amp is mounted, like how far away is it from your subs? And you will be gravy with 12gauge, you don't need to over do it and waste wire you have to cut away to get it to fit in the terminal the amp will be in front of the box, real close to it. i was thinking 10 gauge but i'll do 12 if it don't really make a difference.oh and the speaker wire will be coming out from the port which will be close to the amp. You really don't need it I changed from 12gauge to 8 gauge running 2k to a DC XL, and couldn't tell a difference, nor did the smaller wire get hot, the only difference was the visual one ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
988216855 Posted September 26, 2011 Author Report Posted September 26, 2011 about how many feet will i need to wire two sa 12's dual 4 ohms down to 1 ohm? Depends on where your amp is mounted, like how far away is it from your subs? And you will be gravy with 12gauge, you don't need to over do it and waste wire you have to cut away to get it to fit in the terminal the amp will be in front of the box, real close to it. i was thinking 10 gauge but i'll do 12 if it don't really make a difference.oh and the speaker wire will be coming out from the port which will be close to the amp. You really don't need it I changed from 12gauge to 8 gauge running 2k to a DC XL, and couldn't tell a difference, nor did the smaller wire get hot, the only difference was the visual one so how much should i buy. i want to get karma ss.
988216855 Posted September 26, 2011 Author Report Posted September 26, 2011 help! want to order asap.
