do i have enough room for a t-line?
MACnonsence6
max w-30" max d - 15" max h - 17"
wondering if i have enough space to do one 12 in a t-line.
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
i dont know much about transmission lines. but im pretty sure itd help if you told them whether or not you were gonna use 1/4 wave or 1/2 wave.
i know that will change up how long the line needs to be ALOT
:peepwall:
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
I'm no t-line master either but from what I gather even if you tune to 40 your tunnel will be roughly 7 ft long and your port area needs to be the same as the cone area which is around 100. So your port needs to be 15 by 7 or 17 by 6. In either way you run the tunnel you need 3 passes with your width to get to 7 feet so you are not tall or deep enough for that.
I used rough numbers but all in all I say no.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
No you don't. Here ill do the calculations but im not going to make them pretty
for tline 7 ft long, which is aprox 40hz assuming 12" is the diameter of sub (I don't feel like taking into account surround, doesn't matter)
6*6*3.14*12*7 / 12^3 = 5.495 cubic feet assuming you could use all the space, which you can't.
what you have
30*15*17 / 12^3 = 4.43 cubic feet assuming you could use all the space.
damn alright thanks guys
  • Who's Online   0 Members, 0 Anonymous, 613 Guests (See full list)
