DC Sound Lab
There very well built stable amps
--2004 Toyota 4runner
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
spl dust is an option you can get on the coils... it's great for extra 1000 watts of power
where can i get this spl dust and how much is it. is it hard to apply? lol
I honestly do not know why everyone is so set on advising people to throw a million watts to the level 5. Yes, they can definitely take more but it is obvious that the OP isn't looking at huge power levels, whether or not the drivers have been used and abused as such. I've thrown 4,000 watts plus to each of my BTLs but I still tell people to stick within reason.
I would suggest maybe a single NS-1 to power the both. Unless you're set on 2 amps, then go with the 2500D. Underrated and should be more than enough to pound those subs.
Maybe even a DC 5.0k should be nice
Edited by TeamHT
Hummm, I see.... ill be running @ 0.7ohm so that will eek a little more power out of the 3500ds.
Box is 11cuft tuned to 29hz. Oh and its walled.
Id say 10cf tuned to 34. 29hz probably will sound like ass on most music. And as long as your electrical is stout why not have a lil powere in reserve after rise I doubt you will be getting anywhere close to 3500 w from a 3500. So go big to fight imp rise and maybe have some reserve
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
I've had it tuned to 35 and that didn't sound nice tbh... halved the port to drop the tuning to 25hz and it sounded so much smother and controlled... also played a shed load flatter and louder on the TL.
Playing music... does impedance rise really matter.
Power supply Is two 250a alts externally regged, with 3 d3100s going in.
For me voltage and rise is a factor. When I rail on it with music driving and the rpms are up voltage stays at 15.8 if I'm at idle voltage drops to 14 -13 and amps start to clip as voltage drops which in turn makes subs smelly. Id like to have another 3k on tap to counter this
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
