JacobHazel Posted October 5, 2011 Report Posted October 5, 2011 so i have a 12 inch sub nothing big yet:/ but the box for it is really bad like its small and in closed and i think it was ported at one point and someone messed with it.. so how would i build a new box or should i just buy one and if so what are some good cheap ones
fecupe2001 Posted October 6, 2011 Report Posted October 6, 2011 We need WAY more info than that, what car,power,sub and kind of music you like for example... I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/
JacobHazel Posted October 6, 2011 Author Report Posted October 6, 2011 i have a 2000 dodge dakota, i listen to rap alot, and its a 12inch kicker but i wanna upgrade and get a new sub i just need to know some good ones and i want to spend alot on the sub and the amp is just a 1200 watt amp and the box its self looks like this http://www.crutchfield.com/S-GGvavaIiH56/p_04412T65SM/Q-Logic-12T65SM.html its like a shallow but i have room for a way bigger one
AdamTheAudioMan Posted October 6, 2011 Report Posted October 6, 2011 You need to build your own box, or flip the subwoofer to have more sub area. Save up the money for a SSA DCon 12 or a Sundown 8 or 10. UNDER-CONSTRUCTION ''Old School Build'' maybe it sounds like an 18 cause theres 3 fucking "port" holes ghetto drilled in the "box" 190 db when your done? Yea that's the lowest decibal ill be satisfied with when I'm done like I said its stage one and I lost my job u guys should consider shit instead of just talk it lmao
JacobHazel Posted October 7, 2011 Author Report Posted October 7, 2011 Money isnt the problem and i was looking more toward a Re Audio XXX18 18" Dual 2 Ohm XXX Series Subwoofer or a 12" one.. and you sure the SSA DCon 12 is a good one? and whats some good ways to build it, and what are some good amps
pro-rabbit Posted October 7, 2011 Report Posted October 7, 2011 The enclosure will dictate the results you get in the sub stage. Your equipment will matter, but if you have a less then ideal enclosure (space and/or tuning) you will not like the results no matter if you spend $500 or $1000 on the sub setup. There are many ways to build one, mostly that would depend on your skill level of wood working and how to use tools. If you have never built an enclosure before, a good idea would be to purchase a design with a full 3D model that would allow to you see what your building and would making the process much easier for you. Just be sure the designer is good at what they do and they get you into the right enclosure for the application.
