ok guys im a little confused :peepwall:
here the question,
if i wire a dual 1ohm subwoofer, to a mono amp. example( one coil to side (A)on the amp and the other coil to side (B) on the amp, is the amp going to see 1ohm or .5ohm?????
i know in parallel it a .5ohm and in series it 2ohms, so im guess if i wire each coil to (A) and (B) on the amp it going to see 1ohm correct???
thanks
-Chris
monoblocks have 2 sets of speaker terminals solely for the purpose of making wiring multiple subs easier. doesn't matter if you choose the outside + and - or the inside + and -, itll be the exact same.
wiring each coil to each set of speaker terminals will make the amp parallel the two. so .5 ohms.
I didnt get the point of it at first. Its still a mono amp. There's 2 + and 2 - There just the same terminal connected to each other. So when you connect each coil, either on the sub or the amp, it will be a .5 load.
I cant afford anything...
forum.realmofexcursion.com/members/little-kid-wit-bass.html
Youngest active user on ROE :D
  • Who's Online   0 Members, 0 Anonymous, 758 Guests (See full list)
