I'm not very good with ohm loads so I thought many I could get some help.
I'm going to be running 6 dual 4 subs. Is it posible to run them on one amp at 1 ohm?
If not can I run then 2 amps strapped at 2 ohms?
Or 1 amp per pair off woofers at 1 ohm?
Would 2 ohm subs make a difference???
"SilveradoGoesBang"
http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/
2 FI BTL 18's
CT Sounds 7k
2013 MidwestSPL Finals Xtreme 3 - 1st Place
I think the closest you will be able to get is 3 ohms then strap 2 amps together
Wire 4 sets of 3 voice coils in series to get 4, 12 ohm loads. Then wire each of those in parallel to get a 3 ohm load to the amp.
You could also get a 1.3 ohm load by wiring each of the subs voice coils in series, then wiring each of those 6 subwoofers in parallel to eachother
  • Who's Online   0 Members, 0 Anonymous, 1854 Guests (See full list)
