Only problem I've had with this laptop, the battery is no longer working after a year...Would be nice to use this as an actual laptop and not as a desktop...Can anyone suggest the best place to buy a battery cheap for it? Product ID AA-PB9NC6B, 11.1VDC 48Wh(4400mAh) on the battery.
Also, anyone ever tried seeing if there's a way to replace the thermal paste on the CPU of a laptop? I think mine may need redone, since mine's starting to shut down on occasion on high power settings...
POTATO!
Budget?
But here's one, that's $83
http://www.laptop-battery.co/lenovo-laptop-battery/L08S6Y21-battery/B1797.htm
Edited by AdamTheAudioMan
UNDER-CONSTRUCTION
''Old School Build''
maybe it sounds like an 18 cause theres 3 fucking "port" holes ghetto drilled in the "box"
190 db when your done?
Yea that's the lowest decibal ill be satisfied with when I'm done like I said its stage one and I lost my job u guys should consider shit instead of just talk it
lmao
http://www.ebay.com/itm/Battery-Samsung-NP-E452I-NP-R522-NP-RC710E-NP-Q430E-NP-R530E-NP-RF712-Laptop-/320770729917?pt=Laptop_Batteries&hash=item4aaf6ce7bd#ht_2373wt_1000
EDIT: Another alternative is to pull it apart and replace the cells with new ones and solder them all together, just make sure you get the right ones though. Don't mix nickle metal hydride and lithium or ni-cads so be sure the ones you need work with your charger.
Edited by Skullz
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
But you could just use your power cable to run it, I know that you don't want it as a desktop...
UNDER-CONSTRUCTION
lmao
I was thinking about that, since it's already shot...May give it a go if I can figure out how to pull it apart. They are Li-Ion cells...
That's what I've been doing. Just gets annoying to shut the laptop off, wait 2 minutes to unplug it, move, and plug it back in...
POTATO!
