please explain someone thanks
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
the power train control module controls various engine electrical as well as the tranny.
basically anything that has to do with moving the power both electrical and mechanical around in your vehicle
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
Posted (edited)
so what happens if i add multi 3 amps and my car is PCM controlled?
Edited by KHRISS
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
your engine is going to try and control your alternator to give the vehicle the power it needs to run first. so if you have a large alternator with enough power to distribute everything evenly and fill the engines needs you should be fine.
lets say i add a mechman 320 amp high output alt
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
well you would need to figure out how much amperage your amps will be pulling from your battery.
so if you have plenty of batteries and that alternator then you should be good. you need to have enough amperage to be able to charge your batteries enough to keep up with the demand of you system.
it only takes about 50 amps i believe to run most of the accesories in your vehicle. such as having ac on and lights etc.
so make sure you have enough batteries to run your system. since having an alternator that is large enough to power everything including a large system is going to be difficult and impracticle.
If this anything like the 07+ tahoe ull have to add the alt isolated from the stock electrical and ran to the system battery bank
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
lets say 2 yellow top optimas and a 3500 and 1400 rms amps and the mechman 320 amp high output alt would i be fine with that set up and is it bad or good to have PCM controlled altenator?
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
