If this anything like the 07+ tahoe ull have to add the alt isolated from the stock electrical and ran to the system battery bank
ive actually encountered this. the computer did not want the high output alt to work. it would set off all kinds of dash lights saying service engine soon.
then when the new alt was mounted outside on the bracket it had alot of ground noise. and me and some more experienced poeple could not figure out what was causing it.
and Kriss i would have at least 3 or 4 large batteries for a system like that.
but yes it is both good and bad to have a pcm controlled alt. if you alt is in sufficient the computer will notice before hand and set off warning lights in your vehicle
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
its for my 2005 jeep grand cherokee and the engine size v6 3.7l if that matters too?
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
if i were you i would call mechman or someone to see how yours will work. they have more experience with more specific vehicles. and mechman has great customer service and is great about returning phone calls and answering and questions you have.
warning lights meaning check engine and check battery and stuff like that right ? wow im getting scare now if my wife was to see those warning lights turn on after i changed something in the car i would never hear the end of it lmao
Edited by KHRISS
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
yeah lol. those lights are pretty stupid. but like i said call up mechman and he should be able to get you situated. there might be a bypass that he makes. i know its pretty vehicle specific but it will allow you to control your voltage and bypass your computer
CAR
-2005 Ford Mustang (Legand Lime)
H/U
-Pioneer avh 3200dvd
Amps
2 AQ 3500d.1s strapped 1ohm daily .25burps
1Sundown Audio 100.4
1 Sundown Audio 125.2
Subs
4 AQ HDC'4s 12's
Mids and highs
4 Sundown Neo Pro 8s
2 AQ Super Tweeters
Electronical
Mechman 270 unit
1 D3400
2 D3100's
WALLED!
ok ill do that but what do you recommend me to do to avoid those warning lights and my wife together lol im thinking optima in the front and xs power D3100 in the back with the 320 amp high output alt to avoid those dumb gay stupid light lol would that work?
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
Cherokee? U can get the high output alt in the factory location with a voltage module and b fine with ability to adjust voltage....contact matthew he'll hook u up at mechman
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
yes i agree but with the PCM stuff now the question is if those warning lights come on after i added the alternator what to do and thank you fellas for sharing your knowledge i really appreciate it alot
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
yeah i figured he could. but call matt and hell hook you up. you could prolly go with a 270 amp alt. with the voltage module you wont have any lights.
but id get the biggest bat you can fit up front and then a d3100 in the back. you should be good :good:
  • Who's Online   0 Members, 0 Anonymous, 2199 Guests (See full list)
