chevscalade209 Posted October 11, 2011 Report Posted October 11, 2011 i want to do a 6 12 lvl 2 dc audio build and use a hifonics hfi3000d what do you guys think of the idea? it will be 2001 silverado in a blowthough also how would i wire 6 subs to a monoblock, is it even possible? 2 jl audio 12w3's sealed soon to be 4 level 3 15's blow through all dc audio
__d_a_v_i_d__ Posted October 11, 2011 Report Posted October 11, 2011 hifonics hifi line is garbage, all other hifonics lines are good budget amps.... and you can wire hundred subs into an amp, aslong as all are same, with a stable final ohm load...... Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!!
StatingROBIN Posted October 11, 2011 Report Posted October 11, 2011 Get them all as dual 4 ohm. Wire three of them to 2 ohms and the other three the same way then take those two 2 ohm loads to make a 1 ohm load.
chevscalade209 Posted October 11, 2011 Author Report Posted October 11, 2011 hifonics hifi line is garbage, all other hifonics lines are good budget amps.... and you can wire hundred subs into an amp, aslong as all are same, with a stable final ohm load...... what do you mean by garbage? do they not preform? 2 jl audio 12w3's sealed soon to be 4 level 3 15's blow through all dc audio
TeamHT Posted October 11, 2011 Report Posted October 11, 2011 Tell me...does this smell like chloroform to you?
chevscalade209 Posted October 11, 2011 Author Report Posted October 11, 2011 any other budget 3000watt amps that are better and around the same price that you know of? 2 jl audio 12w3's sealed soon to be 4 level 3 15's blow through all dc audio
Guest Posted October 11, 2011 Report Posted October 11, 2011 hifonics hifi line is garbage, all other hifonics lines are good budget amps.... and you can wire hundred subs into an amp, aslong as all are same, with a stable final ohm load...... what do you mean by garbage? do they not preform? they are built really cheap and dont put out power anywhere near where it says it can.
chevscalade209 Posted October 11, 2011 Author Report Posted October 11, 2011 hifonics hifi line is garbage, all other hifonics lines are good budget amps.... and you can wire hundred subs into an amp, aslong as all are same, with a stable final ohm load...... what do you mean by garbage? do they not preform? they are built really cheap and dont put out power anywhere near where it says it can. so any ideas on a 3000watt budget amp? 2 jl audio 12w3's sealed soon to be 4 level 3 15's blow through all dc audio
