u said u moved stuff, think u moved any grounds, maybe ground loop?
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Wrap a wire around the outer casing of the RCA's on the deck and attach it to the chassis of the deck.
huh! never knew that im gonna have to try that some time....will it work to get ride of the dreaded cop car noise?(the engine whine in the speakers)and what are the advantage's of doin this?
and thanks 4 explaining :good:
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
yes i tried that yesterday with no luck
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
no all the grounds stayed the same. i only rotated the amp
  • 3 weeks later...
okay.. so i got a new HeadUnit plugged everything up and still have the noise.
im guessing my amp is whats wrong. any ideas?
anything guys?
Dang that sucks. Didnt we hook your RCAs to my HU and it worked like normal???
no it didnt
If you used a Ipod connected straight to the amp and the noise went away then it has to be (1) Rca's did you use new one with the new deck... (2) any eq's, crossover's, or anything like that..
Hi SMD Members If anybody has computer problems and is an SMD member with at least 150 posts I will fix your problems for free by phone support or I can also fix your computer over the internet.... I have references such as All State insurance, Nationwide Insurance and much more... just p.m me for help.. I am not the greatest with when it comes to audio systems so I figured I could contribute to the forum this way.... Thanks David
when i plugged up the rcas for the ipod adapter it went away yeah.. but it wouldnt play the music properly.
and no theres no crossovers its all using the amp.
ill try a new pair of rcas on the new deck tomorrow and see what happens. i dont think it will change much.
Basically the signal runs like this..
HU>4channel>subs amp. all using the line in and out features.
Edited by D-train-13k
