bump
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
what do you mean it wouldnt play music properly?
Hammerdown... 1%
it was scketchy sounding. like in and out id have to move the cable to get anything to come out.
im not blaming the amp for that.
i basically cut out the 4 channel and used the subs amp by itself so i plan on switching out the 4 channels and testing them while i try to get this repared
that could have just been a poor connection from the ipod to the amp. Those 3.5mm plugs are notorious for that.
But if you lose the humm then it makes it look like the head unit is the issue, not the amp.
Hammerdown... 1%
im pretty sure i figured it out.. i took the rcas from the back of the HU and plugged up to the subs amp and completely left out the 4 channel and the noise went away and it was playing the radio bass. not loud or anything.
then when i plugged it up to the 4 channel the noise came back
