You got that deal at Walmart Haha. I think its a deh3100 mp. I think
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
I'm mobile soo I cant get a close up of the deck but, can you remove the faceplate? If so do remove the faceplate and look and see if their is a little button, if their is then find something small to push it and hold it in for around 5 seconds
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
I have the same radio no reset button
99.9% sure.
Edited by vettedude102
2003 corvette z06
If their is no reset button which their should be just disconnect the harness connected to the hu for a few seconds and that sould reset it, or disconnect your negative on the batt.... If no reset button
Edit: no reset button? Weird... Well then yea just try what I said above. If resetting it doesnt fix the prob then let us know
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
No need to reset. Pioneer will play as long as theres no shorted speaker.
If 1 speaker is shorted it will kill all output
You said the rears play?
Now try 1 front speaker at a time.
It was a great deal for that and speakers.
It doesn't make sense that they just stopped working. Did you tape the wires together? Also make sure the plug is in all the way just in case.
2003 corvette z06
I think what he did was unhook the sub and put the rear speakers on that amp. Possibly?
2003 corvette z06
Then just unhook all speakers from the deck.
Then hook them up 1 at a time.
You will find the bad one.
If none work then you have a grounded wire or a bad deck
To figure it out
Pull the deck
Power it up only. No other wires
Then put a test speaker right to the speaker outputs on the back of the deck.
If that works then you have a pinched wire
If it doesnt work then bad deck
  • Who's Online   1 Member, 0 Anonymous, 1122 Guests (See full list)
