Krazykid122 Posted October 17, 2011 Report Posted October 17, 2011 ok so i was messing with the RE box calculator, and im not sure how to get it just right, i dont want my port to be to small to have port noise, but when i try and make it bigger and mess with everything else i cant get the tuning as low without messing up the volume. i have 2 10s, trying to put them in 1.5 cubes (.75 each req.) and tune between 33 and 37hz preferably about 35Hz. can anyone help out? im stuck. 02 Dodge Durango 1 Fi SP4 18" .v2 Sundown SCV3k @.5 Ohms XS D3100 up front Northstar SMS AGM 400 in the back All XS Power 0ga OFC 240a Apex h/o alternator Pioneer AVH-X2500BT HU Dual 0ga runs from the alt to battery Dual 0ga runs from battery to amp
blownengine Posted October 17, 2011 Report Posted October 17, 2011 download Torres box calculator from the subwoofer/enclosure section. Its better than RE's 2003 Dodge Ram 1500 SLT (Yea its got a Hemi)Alpine CDA-105KnuKonceptz 0ga CCA Big 3 with Yellow Top 15" SoundQubed HDC3DC Audio 1.2K (Bass)Pioneer 6x9's (Front)Pioneer 6.5's (Rear)Kicker 3.5's (Dash)Sony amp on the highs. (Hey it was free)
extremeauto Posted October 17, 2011 Report Posted October 17, 2011 ok so i was messing with the RE box calculator, and im not sure how to get it just right, i dont want my port to be to small to have port noise, but when i try and make it bigger and mess with everything else i cant get the tuning as low without messing up the volume. i have 2 10s, trying to put them in 1.5 cubes (.75 each req.) and tune between 33 and 37hz preferably about 35Hz. can anyone help out? im stuck. i just looked @ re box calculator and it is a lil off most of the time but i came up with a box that may workhere is what u need to type in box width...28" hight.18" top depth.18" bottom depth 18" sqaure port with 3" sqaure port lenth 12" this should give you 3.292 cubes and tune u @32hz-34hz (Re seem to be of a lil bit) anyway thtas the best i could come up with fast i will look into it later to be sure ...im sure some1 with more knowledge will correct me if i am wrong as well...good luck and be sure to build it with glue and screws....if you can i would 45 all corners as well. 1995 Honda passport 3.2 4x4 Frankenstein on a budget ballistics sound deader (roof only so far) kenwood mp3 usb audio control 3 (upgrading) hifonics mx-3 3 sets of massive px5 5.25s 3 sets of massive tweets phonix gold 5.25 componets x2 massive nx4 nano 200x4 mids sony xplod 600x4 watt high's 2 Fi bl fully loaded box walled @31ish hz 13.2 cube box/wall massive DB8000 Excessive amaperge 250 amp alt wir extrnl regulator daul runs of xs power xpflex 0 gauge big 3 raptor 0 gauge power/ground wire full run suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt scytek galaxy 2way alarm still upgradeing!
RAM_Designs Posted October 19, 2011 Report Posted October 19, 2011 What subs? 1.5ft^3 for a pair of 10's is generally pretty small. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
