im about to be running an American Bass VFL 100.1 (1500+rms) in a celica with a stock alternator. I think the alternator is around 80amps. I'll also be doing the "big 3" up front and adding a kinetik in the back. Shortly i'll be starting to run 0gauge, but I dont know what size fusing to use on big3 or the run to the rear. any help?
so your gonna put 3 batteries in there right?
--2004 Toyota 4runner
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
spl dust is an option you can get on the coils... it's great for extra 1000 watts of power
where can i get this spl dust and how much is it. is it hard to apply? lol
8O amp inbetween alt and batt(within 12" from batt). Now from batt to amp wire a 250 should be fine 12" from batt. And check the specs in the amp manual but I'd say a 150? before the amp.? And a 250 before the second batt.
Edit: I think I was wrong my 90amp alt takes a 100amp fuse soo if your alt is 80amps I think a 9O amp fuse would be best.
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
it you are using OFC wire you should use 300a fuses and then fuse the amp for what the manual says the fuse rating is
Btw that was the first person. Ever banned by me while dropping a deuce. Feel privileged
If you cant find specs on your alt go to autozone and ask what the stock alt is they have it in their system, so you know what to fuse the big 3 with.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
no...stock up front with the big 3 upgrade, run of 0gauge to a kinetik in the back
At least have 2 good batteries and generally don't mix lead acid with agm battery's.
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
i've had tons of people telling me that in a daily driver on only 1500 watts, i should be fine with the 2 different types of batteries
And tons of people from where? Im just saying from personal experience and everyone i've known it works much better with 2 matching batteries. Better safe then sorry especially on 80 amps but that's just me. :shrug:
New Build Log
-2002 Acura Tl-S
Old Build Log
Team DC Audio
xs pwoer says as long as they are both 12v batts you are ok i wouldnt waste my time with kinetik or however you spell it
  • Who's Online   0 Members, 0 Anonymous, 2284 Guests (See full list)
