gotFI? Posted November 9, 2007 Report Posted November 9, 2007 my sister bought a USED car from a dealer with no warrenty last friday. the shit is overheating. so she took it to a hole in the wall mechanic, when it comes time to start the car after he does a fews thing to it, it wont start. he has no idea what it is and he said hes not reponsible for it. the car started and ran fine to the shop. since he fucked with it, it wount start. what can i do lawfully or say to make this guy fix it for free. Quote
str86diesel Posted November 9, 2007 Report Posted November 9, 2007 First of all, you need to have documented what he did to the car. If he did any work without her signing a waiver, letting her know what he is going to do, then your screwed. If she did sign a waiver, then that is proof that he had the car and worked on it. As far as the car overheating, here is a couple of quick items for you to check out on the car. 1) Is the car leaking coolant? 2) Usually on one of the sides of the radiator on the bottom is the thermostat. If you pull this out, is it stuck closed? 3) Does the motor even have any coolant in it? 4) Is it a newer car? Newer cars use that pink or orance coolant and i know lots of people have topped off their coolant with the green/yellow stuff and these two type of coolant don't mix and turn into a gummy substance which clog up the hoses, which cause the car to overheat As far as the not starting, have you guys checked the battery or distributer to make sure they are ok and hooked up correctly? Are the plug wires attached to the plugs? Is the car carb'd or fuel injected? Quote 2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
gotFI? Posted November 9, 2007 Author Report Posted November 9, 2007 i can troubleshoot the overheating problen myself. but she went to a mechanic instead. what can i do to make the mechanic fix the problem. CAR NOT STARTING. still at shop. he wants nothing to do with the car after he broke it. Quote
kevinb721 Posted November 9, 2007 Report Posted November 9, 2007 take that bitch to court! Quote 12" fi q rf t10001 naw mean
str86diesel Posted November 9, 2007 Report Posted November 9, 2007 If he is unwilling to own up to his actions, there is nothing you can do to force him to work on the car. If you bring in an LEO (law enforcement officer), they might help you reach an agreement with the mechanic, but unless there is signed paperwork that he is working on the vehicle you have nothing. Quote 2k6 Dodge Ram 2500...CUMMINS POWERED - SOLD
BURRITO Posted November 9, 2007 Report Posted November 9, 2007 you gotta have some BIG ones to do this, but..... park your car right smack dab in the middle of thier driveway (with hazard lights on, that way it would require a LEO to have your car towed) have your sister march around her car holding a very LARGE sign that states what they did to the car and how they plan on taking care of this matter... they should be more than willing to fix her car before the first news crew gets there FTW!!! Quote Barretto MotorsportsTeam RFCTeam CHMTeam SMD "Blow Sand"Live Your Life Without Boundaries... http://www.jeffbarretto.acnrep.com/d_oppor...A=US_EN&BW=
bibby>Chode Posted November 9, 2007 Report Posted November 9, 2007 you gotta have some BIG ones to do this, but..... park your car right smack dab in the middle of thier driveway (with hazard lights on, that way it would require a LEO to have your car towed) have your sister march around her car holding a very LARGE sign that states what they did to the car and how they plan on taking care of this matter... they should be more than willing to fix her car before the first news crew gets there FTW!!! That is ballsy, but would definatly do the trick. Get some friends to go with you.... Angry Mob > 1 Person Quote
mrwigglezdj Posted November 9, 2007 Report Posted November 9, 2007 a guy did that in town at the local walmart because they fucked up on his oil change and didnt readd the oil lol so he had his car towed back to walmart and droped off infront of the shop area and he protested walmart untill they fixed it Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
