layzeepinoy23 Posted October 20, 2011 Report Posted October 20, 2011 Got a pair of alpine type r , 2 sets of alpine coax, and 2 hifonics amps in trade for some labor and my girl decided she wants them in her car. Question is, what would I need to upgrade in her van to support 1800 watts total; subs and mid/high (probably won't see that much but better safe than sorry). It has big 3 done in 4ga since I had some laying around and figured why not as well as the stock 130amp alternator.
AI James Posted October 20, 2011 Report Posted October 20, 2011 maybe add a second battery. and make sure you have great grounds
layzeepinoy23 Posted October 20, 2011 Author Report Posted October 20, 2011 maybe add a second battery. and make sure you have great grounds Hmm that's it? Sweet. In that case would it be okay to use 4ga to go to the 2nd batt? I should have enough to do 2 runs pos neg today. If not then I'll just have to order up some 0ga. Also, whats the smallest batt that would be acceptable, I'm sure bigger is better but not trying to put too much into this.
bumonskateboard6 Posted October 20, 2011 Report Posted October 20, 2011 maybe add a second battery. and make sure you have great grounds Hmm that's it? Sweet. In that case would it be okay to use 4ga to go to the 2nd batt? I should have enough to do 2 runs pos neg today. If not then I'll just have to order up some 0ga. Also, whats the smallest batt that would be acceptable, I'm sure bigger is better but not trying to put too much into this. I'd wire the batteries in parallel with 0ga just so there's less resistance. As for battery I'd look at a D925 or D975 they're small but can back up a system pretty well. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
