BassMonsterZ Posted October 21, 2011 Report Posted October 21, 2011 Hi to all,I have some question to ask and i hope to get some answers My question is if the following measures are ok for a FI SSD 18" (i want brutal bass, a huge pressure, feel bass hits my head and also get accorded at low frequencies like 30-33 but at the same time sound quality) Box: 6.6 cu.ft Box Width = 27.55 inches (70 cm) internal Box Height = 19.68 inches (50 cm) internal Box length = 19.68 inches (50 cm) internal Box thickness = 1,18 inches (3 cm) (Rectangular airport) Air Port height = 11.81 inches (30 cm) Air Port width = 3.93 inches(10 cm) Air Port length = 15.74 inches ( 40 cm) Air Port thickness = I dont known This is the box project from the top, the red color indicate the port thickness: I calculated the measures with the help of Bass Box Pro 6 and it said with this dimension of box/air port will get tuned to 33.57hz So what do you think about a box like that? would be good for a FI SSD 18"? How much must be the thickness of the airport? I hope to type the measures correctly because i'm not from the US or America so i use another metric measures.
412 CVX Posted October 21, 2011 Report Posted October 21, 2011 Hi to all,I have some question to ask and i hope to get some answers My question is if the following measures are ok for a FI SSD 18" (i want brutal bass, a huge pressure, feel bass hits my head and also get accorded at low frequencies like 30-33 but at the same time sound quality) Box: 6.6 cu.ft Box Width = 27.55 inches (70 cm) internal Box Height = 19.68 inches (50 cm) internal Box length = 19.68 inches (50 cm) internal Box thickness = 1,18 inches (3 cm) (Rectangular airport) Air Port height = 11.81 inches (30 cm) Air Port width = 3.93 inches(10 cm) Air Port length = 15.74 inches ( 40 cm) Air Port thickness = I dont known This is the box project from the top, the red color indicate the port thickness: I calculated the measures with the help of Bass Box Pro 6 and it said with this dimension of box/air port will get tuned to 33.57hz So what do you think about a box like that? would be good for a FI SSD 18"? How much must be the thickness of the airport? I hope to type the measures correctly because i'm not from the US or America so i use another metric measures. i'm not entirely sure of what to do with those numbers... Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
RAM_Designs Posted October 22, 2011 Report Posted October 22, 2011 Don't do the port like that. Use the right wall of the box as the right side of the port. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
BassMonsterZ Posted October 22, 2011 Author Report Posted October 22, 2011 Don't do the port like that. Use the right wall of the box as the right side of the port. Except that, the dimension of the box are good?
412 CVX Posted October 22, 2011 Report Posted October 22, 2011 it's hard to say. centimeters don't convert well into inches. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
