XS Power batts and Singer 230 alt
Okay guys wondering what yall think i should do as far as buying a new alt and batts, i currently have a d3400 and a d3100 on a stock 105 amp alt, should i (A) get 2 more d3100s and keep the stock alt or (B) get 1 d3100 and one 230 amp singer alt.... plan on doing 2 sundown 4500's yes i know ill need more batts than that but for temporary... Thanks!
Youtube Account : Bassman1439
New Build in progress:
1987 Jeep Cherokee
153 BT Alpine with 3 clarion eq 746 2 clarion mdc360 crossovers
Alternator
Mike Singer 230a and 350a
Amps
Taramp HD8000
Taramp HD6500
Taramp 5000
Taramp TS1300x2
Taramp 2000
Mids
16 Beyma mi100 8's
10 Beyma mi100 10's
4 beyma mi100 15's
Highs
16 selenium st 350's/ 8 d250x horns outside
Batts
D3400 under hood and 8 d3100s
Sub Stage
6 XL DC 15's 2 9KS
For now i would just get the d3100 and the singer alt, is that the biggest alt they make for your truck? if not i would try to get the biggest one so you wouldnt have to upgrade it again down the road. When all said and done after you get the money for the batteries i would have a minimum of 5 since those amps love the power.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
What vehicle? And is 230 the biggest you can go? Imo alternator is always better. I have 3 with total output at over 1000amps and 6 xs1400s on 10k plus. I only drop .2 fulltilt. If I just run 1 350 amp alt it will drop almost a full volt or more. This is all above idle.
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
its a 87 jeep cherokee, i checked with singer and this is the biggest direct bolt on i can get without customizing a bracket for a bigger one... so diff go with 1 alt and the 1 d3100 to add on to what i got now?
1987 Jeep Cherokee
Alternator
Amps
Taramp HD8000
Taramp HD6500
Taramp 5000
Taramp TS1300x2
Taramp 2000
Mids
16 Beyma mi100 8's
10 Beyma mi100 10's
4 beyma mi100 15's
Highs
Batts
Sub Stage
6 XL DC 15's 2 9KS
get the alt and single battery. add more batteries later
okay my mind is made up haha
1987 Jeep Cherokee
Alternator
Amps
Taramp HD8000
Taramp HD6500
Taramp 5000
Taramp TS1300x2
Taramp 2000
Mids
16 Beyma mi100 8's
10 Beyma mi100 10's
4 beyma mi100 15's
Highs
Batts
Sub Stage
6 XL DC 15's 2 9KS
  • Who's Online   0 Members, 0 Anonymous, 1382 Guests (See full list)
