So close to 1.5yrs ago, I put a junk yard motor in my daily driver. Well when I got it the knock sensor was on the intake manifold, (no idea why) and I assumed it was a big ground lol... I had torn the old engine down and neglected to take enough pics.... So something seemed odd when I was checking my oil and stuff today. I've been trying to figure out why my gas mileage has been sucking... So I was staring at the knock sensor and realized it was a knock sensor.... Now have moved it to the correct location... I was curious does anyone know if the knock sensor being in the wrong spot will affect gas mileage?
no lights have ever come on or anything, I feel like an idiot though lol
Edited by armykyle1
No, Might have a plugged cat, bad o2 sensor, bad egr, worn timing chain/belt or even a few more things combined that may be effecting your mileage.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
the cat has close to 250xxx miles, so it could def be an issue. Put a new timing belt and head on it about 5k ago, tested the egr and cleaned the carbon out of the lines. I know its running rich
I think it is the one downstream so it would be the one after the cat, but i would check both if you have 2 on your car.
I've been kind of thinking the cat for a while or the o2, But cats for my car a min of 250 lol. The upstream o2 is only like 15 bucks but the down stream is 80-100 for a good brand.
afaik the cat will not cause mileage drop, unless it is clogged, if its not then you just are not following emissions requirements
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
there is no emissions here :)
  • Who's Online   0 Members, 0 Anonymous, 519 Guests (See full list)
