Fastest way crimp caps would good crimpers kliens. Most will say solder then heat shrink. That takes a lot longer
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
This for wires that aren't going to be moved often. A good crimp can withstand some tension. For larger I would always solder. I hate when my crimped 1/0 f***s up
ive always just used crimps. use a real crimper though, dont just use pliers.
Happened to me like 4 times now... soldering FTW.
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
  • Who's Online   0 Members, 0 Anonymous, 1127 Guests (See full list)
