Well I want to know what would be the correct steps to detail/restore the paint on my 66 Dart?
Like I always here about polish, compound, claybar, and wax, but I am curious on what order they need to be done?
I was using some Turtle Wax brand Polish/Compound on the dart to help remove some of the oxidation. It would work good when I could get the compound off but the stuff dried up so fast it was super difficult to remove. I tried using my craftsman electric polisher and it wasnt much help either.
Any kits or brands you guys suggest?
Thanks alot!
For most paint restoring projects I usually go in these steps.
Products:
Dewalt variable speed buffer (a must have)
3M white foam pad (compound)
3M black foam pad (polish/glaze)
3M clay ball
3M compound
3M machine glaze
Wizards hand glaze
1. Wash and rinse car thoroughly (repeat)
2. Use fresh soap and water and clay ball complete car
3. Wash car again
4. Dry car completely (use air hose on all molding and jams)
5. Tape off all chrome and plastic
6. Go panel to panel with compound
7. Repeat till shine is deep
8. Go panel to panel with machine glaze
9. Repeat
10. Wash car again ( yes again)
11. Dry completely (use air gun)
12. Go over complete car with hand glaze (repeat if desired)
13. Use detailing brushes to get in all hard to reach places and finesse cleaning.
After all this you should have the shine and depth of a "like new" paint job!
I hope this helps, but I assure you, this is a full days job, but if executed properly, your finished product will certainly be worth it!
Edited by Audio-Concepts
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
Your going to want to wax or seal the paint on that Dart after you get it polished out. No sense in spending all that time and not protecting it from the elements.
I have been using Adam's polishes stuff. Its pretty high dollar but customer service is some of the best I have ever came across and the products are the best I have used. The way they set up their products its easy easy to use and you know exactly what chemical does what. http://www.adamspolishes.com/ go to the website and watch the detailing videos they will give you so much more info and some of the proper steps to doing good work.
Lately just to try out different things I have been ordering from https://www.detailedimage.com/ good prices on a lot of stuff.
Chemical guys is also a really good company but they have a crap ton of products and it can get really confusing with them because they have so many different things that can do the same thing.
I tend to stay away from anything from vatozone or anything like that after buying good products online. They are so much better quality and a better deal.
90% of the finished product comes down to the procedure and prep work. So good technique is key.
youve got a dart too? check out the build in my sig. i own a 1973 swinger building it. check it out.n im re
Lucky Durango
Sony hu
4 croosfire 6.5mids
crossfire 600.1 mono amp
American bass 1280.4 mids and highs amp
aq hdc3 12
2.4 cube net box, tuned to 34 and 14.4 inches of port per cube
Products:
3M clay ball
3M compound
3M machine glaze
Wizards hand glaze
3. Wash car again
9. Repeat
This guy knows what hes talking about :good:
  • 3 weeks later...
Products:
3M clay ball
3M compound
3M machine glaze
Wizards hand glaze
3. Wash car again
9. Repeat
Need to be careful with a buffer. Can burn the paint real quick if your not careful. Not a good idea to use the buffer all the time on the car either because each use takes off paint. But that is the correct way to detail a car and make it nice. Just my two cents.
2012 Nissan Altima SL
DC M2 Lvl 3 12" with AR cone
DC 1.2K Amp
Kicker Sum8
Kicker 4 Gauge amp kit
XS Power D2700
1.5 Cubic ft net tuned to 38Hz
Where do you go about getting these products?
You can get most of the stuff at Autozone or Advanced, but to get the best stuff go to automotive paint jobbers or wholesalers!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
When using a buffer, the pad will turn clockwise. When buffing on flat surfaces keep the buffer flat an keep it moving, pausing your motion or staying in a spot will burn the paint. When doing the edges angle the buffer slightly upwards so the pad is spinning off the edge NOT towards the edge.
You also dont need to cake the compound on the panels, use it lightly and sparsely. I usually keep my buffer speed between 1200 & 1500 rpm, you still have good speed and control!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
  • Who's Online   2 Members, 0 Anonymous, 1200 Guests (See full list)
