lytesson Posted October 24, 2011 Report Posted October 24, 2011 I have this amp: sony-XM-ZZR3301 I recently blew out my sub and got a replacement until I can afford to buy the one I had originally. My only problem is that this sub runs at 8-ohm. How can I wire my sub up to run at 8ohm? 1996 Jeep Cherokee Country Sony CDX-GT240 Head Unit Sony XM-ZZR3301 1100W Max ZR Series Class D Monoblock Amplifier Alpine SWR-1243D 12'' Dual 4 ohm Type-R Series Car Subwoofer 2x Alpine SPS-510 5-1/4'' Coaxial 2-Way Speaker Set 2x Pioneer TS-G1344R 5-1/4'' Coaxial 2-Way Speaker Set Fully Insulated with Peel-N-Seal
chronic2001 Posted October 24, 2011 Report Posted October 24, 2011 Is it single or dual voice coil? Www.the12volt.com has sub wiring diagrams. Pioneer deh-8300UB 6- Image Dynamics CSX6.5v2 4-Image Dynamics XS-28 tweeters 4-Sundown Audio sa8v2's 1-Sundown Audio SAX-200.4 1-Sundown Audio SAX-1200d 1-Mechman 270a alternator 1-XS Power D3400 under hood Second Skin Damplifier Pro Deadener Kicker & Knukoncept 1/0 wiring Big 3 upgrade
CleanSierra Posted October 24, 2011 Report Posted October 24, 2011 Indeed...what sub are you running? Im not the one you want to try to troll. Just a fyi for you.
lytesson Posted October 24, 2011 Author Report Posted October 24, 2011 Eh I don't have the model number infront of me but its basically a shitty subbrand of memphis audio. Its a single voice coil 1996 Jeep Cherokee Country Sony CDX-GT240 Head Unit Sony XM-ZZR3301 1100W Max ZR Series Class D Monoblock Amplifier Alpine SWR-1243D 12'' Dual 4 ohm Type-R Series Car Subwoofer 2x Alpine SPS-510 5-1/4'' Coaxial 2-Way Speaker Set 2x Pioneer TS-G1344R 5-1/4'' Coaxial 2-Way Speaker Set Fully Insulated with Peel-N-Seal
Guest Posted October 24, 2011 Report Posted October 24, 2011 if the sub says its 8 ohms then its already at 8 ohms. nothing you need to do. but your question is redundant. you say its at 8 ohms, but you're asking how you can run it at 8 ohms...
lytesson Posted October 24, 2011 Author Report Posted October 24, 2011 Oh, I thought my amp only put out either 4 or 2ohm load EDIT: model num 15-SE12S8 if the sub says its 8 ohms then its already at 8 ohms. nothing you need to do. but your question is redundant. you say its at 8 ohms, but you're asking how you can run it at 8 ohms... 1996 Jeep Cherokee Country Sony CDX-GT240 Head Unit Sony XM-ZZR3301 1100W Max ZR Series Class D Monoblock Amplifier Alpine SWR-1243D 12'' Dual 4 ohm Type-R Series Car Subwoofer 2x Alpine SPS-510 5-1/4'' Coaxial 2-Way Speaker Set 2x Pioneer TS-G1344R 5-1/4'' Coaxial 2-Way Speaker Set Fully Insulated with Peel-N-Seal
Guest Posted October 24, 2011 Report Posted October 24, 2011 no your amp can run at 32 ohms if you had the speakers to do so, it would just output barely any power.
lytesson Posted October 24, 2011 Author Report Posted October 24, 2011 Thanks man, appreciate the help /close thread no your amp can run at 32 ohms if you had the speakers to do so, it would just output barely any power. 1996 Jeep Cherokee Country Sony CDX-GT240 Head Unit Sony XM-ZZR3301 1100W Max ZR Series Class D Monoblock Amplifier Alpine SWR-1243D 12'' Dual 4 ohm Type-R Series Car Subwoofer 2x Alpine SPS-510 5-1/4'' Coaxial 2-Way Speaker Set 2x Pioneer TS-G1344R 5-1/4'' Coaxial 2-Way Speaker Set Fully Insulated with Peel-N-Seal
