01VWGREENMACHINE Posted October 26, 2011 Report Posted October 26, 2011 ok ill make a long story short i just rebuilt my motor and trans. i ordered a 200 amp singer alt. i got the car put back together started great runs fine but if i hook the clamp to the wire coming directly off the alt i get 4.5 amps with the car running and as it runs the batt drains starts at 12v but slowly declines till car shuts off (shuts off at about 10.2 volts) im getting pics up right now ill post them. any ideas??? thanks in advance!!!! take in mind all the big 3 is the same as before and i have no amps or extra batts hooked up at the moment. http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
miniSPLlancer Posted October 26, 2011 Report Posted October 26, 2011 ok ill make a long story short i just rebuilt my motor and trans. i ordered a 200 amp singer alt. i got the car put back together started great runs fine but if i hook the clamp to the wire coming directly off the alt i get 4.5 amps with the car running and as it runs the batt drains starts at 12v but slowly declines till car shuts off (shuts off at about 10.2 volts) im getting pics up right now ill post them. any ideas??? thanks in advance!!!! take in mind all the big 3 is the same as before and i have no amps or extra batts hooked up at the moment. check to see if it has an adjustable voltage on it, my Mechman does and I can set high or low, now it may be a bad alternator, it happens. But chk if you can change the voltage on it first. 2011 Mitsubishi OutlanderSony 712 Soundqubed HDS208 Alpine MRV-M500 Transmission line enclosure Soundqubed wiring Knu rca XS Power battery CNF terminals
01VWGREENMACHINE Posted October 26, 2011 Author Report Posted October 26, 2011 ok ill make a long story short i just rebuilt my motor and trans. i ordered a 200 amp singer alt. i got the car put back together started great runs fine but if i hook the clamp to the wire coming directly off the alt i get 4.5 amps with the car running and as it runs the batt drains starts at 12v but slowly declines till car shuts off (shuts off at about 10.2 volts) im getting pics up right now ill post them. any ideas??? thanks in advance!!!! take in mind all the big 3 is the same as before and i have no amps or extra batts hooked up at the moment. check to see if it has an adjustable voltage on it, my Mechman does and I can set high or low, now it may be a bad alternator, it happens. But chk if you can change the voltage on it first. no adjustments http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
ChevyBoy95 Posted October 26, 2011 Report Posted October 26, 2011 make sure you have the stock plug in, the one with the pins in it. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
01VWGREENMACHINE Posted October 26, 2011 Author Report Posted October 26, 2011 make sure you have the stock plug in, the one with the pins in it. i checked that made sure everything was plugged in http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
varietyguy Posted October 26, 2011 Report Posted October 26, 2011 clamp your ignition line to see if it is powering on the alternator. 1992 Mazda 323 http://www.stevemead...323-wall-build/
Guest Posted October 26, 2011 Report Posted October 26, 2011 maybe the engine is spinning too slow for the alt to turn on?
01VWGREENMACHINE Posted October 26, 2011 Author Report Posted October 26, 2011 maybe the engine is spinning too slow for the alt to turn on? i put the original alt back in and she fires right up no issues i just took it to an alt specialist (a place that builds them) payed 20 bucs for a test and it failed the regulator test. thanks for the ideas!! http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
