Help picking out an amplifier
Hadec
I was going to buy (2) Fi BL either 12" or 15" subs. They are both 1500 RMS at 2 ohms. So together they are 3000 RMS. Where can I buy a cheap amp to power 3000w RMS at 2 ohms? Or am I mistaken and it needs to be 1500w at 2 ohms?
www.ficaraudio.com/sess/utn;jsessionid=154b7b0660de75a/shopdata/0050_Speakers/0020_BL/product_overview.shopscript
Edited by Hadec
Working on my first car audio build ever!
Currently have:
- 1996 Lexus LS400 sedan
- Diablo Hellfire Proto Amplifier
- (2) 12" Fi Bl Subwoofers
- Vented subwoofer enclosure from Perfect Soundz
- Installed by Perfect Soundz
Needs:
- Battery: probably XS Power 12V 2400
- "The Big 3"
why dont you get D4s and run them both at 1ohm? Its alot easier to find a 3k amp that does power at 1ohm rather then 2
Edit: didnt realize they dont make D4s. Get D1s and run the pair at 1ohm
Edited by jagblazer01
Team Sundown Audio / Team XS Power / Team SHOK
SMD Super Buyer/Seller
www.sundownaudio.com
www.shokindustries.com
www.4xspower.com
www.excessiveamperage.com
Thanks, I will look into those amps. I am a little confused with the amps though. http://www.audiopipe.com/products/amplifiers/ap/ap-30001d.html
3000W x 1 @ 2 Ohm Does this mean it will power only one sub at 3000w?
I will either have it set up behind the back seats or in my trunk.
Which do you guys prefer? I have pictures of both areas of my old Lexus.
Edited by Hadec
Currently have:
Needs:
- "The Big 3"
What is your budget like? Maybe I missed it but yes definitely get 2 D4's and run at 1ohm. Depending on your budget, can then figure out an amplifier.
Old Setup
03 DurangoRF Power T1 6.5 CompsMids/Highs Amp: AQ4x90Sub Amp: AQ 3500.1DSubs: 2 DC XL 18sBox: 12ft^3 tuned to 33HzMechman 270 Amp AltXS 6500XS 3100 x2
Highest Score to date: 151.2 db @ Headrest
No more than $400 probably. And that's stretching it. :/
Currently have:
Needs:
- "The Big 3"
The Audiopipe may be the way to go then. I will look around a little.
3000x1 @ 2 ohms means if you had 1 speakers ran at 2 ohms it would receive 3000 watts.
Since you're running 2 speakers at 2 ohms they will each receive half of that, so 1500 per sub.
I will look again to verify but I am pretty sure the 3k is just two 1500s strapped internally, or atleast they use to be, so you could run that amp at 1 ohm and get 1500 to each sub. I will check that tho, give me a sec.
Edited by DGold
Old Setup
Yes please check. :)
I was looking on youtube at some set ups and (2) RF T1500-1bd amps work perfect. Too bad i don't have the money for that lol.
Currently have:
Needs:
- "The Big 3"
haha yeah they would, or if you save up a little a Crescendo 3k would make you very happy, i believe they are around 550. That Audiopipe will work fine tho aslong as you wired it up correctly.
Old Setup
  • Who's Online   1 Member, 0 Anonymous, 1205 Guests (See full list)
